Another ground point thread!
2 reading
26 views 2 replies 3 participants last post by  gregoryx
#1 ·
I'm trying to figure out where to ground my electrical system, which will be located between the front seats of my 2024 Transit and includes a 2000W inverter. I see a lot of threads regarding grounds in that area, but for older Transits with different grounding points.
I have points 78 and 79, as shown in the 2024 BEMM, but they appear to be small and are listed as connected to "Front Floor/Turret/Fender." So, they seem to be light duty?
76 and 77 are listed "Front Frame Crossmember" which sounds good...but I don't see them in the van.
Suggestions? Are 78/79 actually ok to use for this? Should I run it to the B pillar D ring as others have done? Something else?
#3 ·
I'd have to go pull the center-cover again... but what about that one mid-photo? Sure seems like that was the most solid point in the previous BEMMs. I wouldn't be thrilled with #79 for a high-load ground. And if #78 is smaller, as it appears in the photo... even less thrilled with that.
Normally, I'd recommend the B-pillar, but if your whole electrical system will be sitting on top of that middle section, that seems like the place to go for the ground. It seems like #76/77 - near the old parking brake - were also really good; but that may all be different in the newer models.
If you go B-pillar OR if you use a currently-painted point (maybe why they're not recommending that middle one), here's what I'd want it to look like before I put on a beefy ground:
Bit of conductive grease behind the lug then locked down.
