I would estimate that 20% of plus nuts I've installed have ended up spinning - not pressing up against the backside of the metal enough to lock into place and allow full tightening of the bolt. It's entirely possible it's my technique but after doing 125 of them, the success rate hasn't improved. "You're a slow learner" you might say... and you may be right but when I've tried to tighten further, the stem deforms and the bolts don't thread properly.
Once the bolt is in and the spinning begins, particularly if it's in a structural element where its difficult to get ahold of the "plus" to secure it, it's a PITA to get the bolt out. I've had to Dremmel out several.
The other explanation could be that the items were poor quality. Here are the ones I used https://www.amazon.ca/gp/product/B008VGWFAI.
If anyone were to ask my advice, I would certainly suggest people be very cautious about using them. I've put rivnuts in places where I thought the pressures would be less and have had absolutely no problem with them spinning or coming loose. I will use them exclusively in future projects.
Others had similar experiences?
